Many people are not aware that you can do a multiview in Wyze because it is called groups. Rename groups to Multiview so it’s more intuitive.
Grouping applies to more product types than cameras, eg. sensors and bulbs. Therefore, renaming them to multi-view wouldn’t make sense for those other products.
When you first load the app, there are tips that pop up. Do you think one of these pointing at the (…) icon and saying “View multiple cameras” would help?
Personally I find that people rarely pay attention to the tips that pop up on apps when you first install as you’re usually not ready… Maybe if that tip popped up when someone added a second camera?
Based on the feedback my reddit post received it appears this feature is not well known and is one of the most important of all! Further, I find that reddit users are more tech savvy so that should say something too.
A
You may want to submit a #wishlist topic titled something like “Popup explanation of multi-view when adding 2nd camera”.
I was just trying to give advice. It’s not on my wishlist!
