While monitoring a camera, I would like to pre-select a region and if there is movement in that region to play a sound.
This is good for monitoring both elderly and small children. Example: Put the crib on one side of the screen and specify a region on the other side. If the child crawls out of the crib and crosses into the region you play the sound file to catch the parent’s attention.
You can already do this. First specify a detection zone in the camera settings. Then turn on motion detection and push notifications. Finally, make sure you phone is set to play a sound on receiving the push notification.
