" To set a detection zone, simply select a camera, go to Camera Settings -> Alert Settings, and find the Motion Detection Zone section at the bottom of the screen. If Full screen is enabled, toggle it off to be able to access the Set detection zone screen. You can then drag the corners of a rectangle to set the zone. Don’t forget to press Save to complete your selection!"
I don’t understand these instructions. Go to Camera Settings where? On what device?
On the app you use. Iphone, Android etc. Bring up the live view of the camera, click on the settings icon in the upper right of your screen, then click on “alert settings”. At the bottom of that page you’ll find “Motion Detection Zone” That’s it.
When I click on the settings icon and then alert settings, there is nothing at the bottom of the page. I am using version 3.9.3.62 . I don’t see “Motion Detection Zone”
