Question: How to configuring Wyze PIR and Pixel based motion detection
Questions that I am unclear about:
–When Wyze PIR sensor is configured to record a sensor video on a particular Wyze Cam, does that automatically disable Wyze cams pixel based detection or one has to manually toggle OFF the motion detection in Event recording settings?
–Is it possible to trigger both pixel-based and PIR sensor motion alerts on the same CAM?
  1. It has to be toggled off in event recordings.
  2. Yes
Yes , at the same time
