can other wi-fi cams work Wyze cam?
Welcome to the community, @frncstm! Can you be more specific with your question? Thanks.
if you are wondering if the Wyze cams can be used with the DVR aspect of the Q7 wifi cam or within the same APP, it can not. Also if your asking if the Q7 cam can be used with the Wyze cam app, that is also a no go.
Sorry, I just had this Camera I bought several years ago that I never used and wondered
since it was plug and play if it would work with my Wyze cam with the bridge set up. oh and thank you:)
thanks for taking the time to answer!
