Push notification sound stuck at system default, not possible to switch to Wyze sound 1/2/3.
Any idea how to fix this?
As an Android user, you should be able to set virtually any sound you want for the notifications, but if you specifically want the app-provided sound you may need to completely uninstall and re-install the app (I tend to reboot the phone after uninstalling and installing apps out of habit with Windows software) in order to get those sounds to work. I accidentally discovered fairly recently that this worked for me, and then I read elsewhere online that this sort of thing sometimes happens with other Android apps with app-provided notification sounds, so it doesn’t seem to be an issue peculiar to Wyze, more of an issue with the way Android handles things during app updates.
