I have suggestion for the app. I use the cam v2 for outdoor monitoring of front drive and entrance. Works great! No problems. But I get many many triggered events from birds in the day and flying insects at night. In the app I have to load each event to delete it. This is a chore. I can tell these events just from the triggered panes. I would like a way to select events with a check box so one can delete those with one stroke and not have to open each one. Thanks
Hi @halds, and welcome to the community. Please see the “Events Tab” section of this support page. That very function is described in detail there.
@halds going on what @robliberty said, you can also do a “select all” following his instructions. this will check mark all the visible recordings at that point( visible on the screen). so if you have quite a few you are going to have to do select all a few times but you can quickly delete a bunch without individual selection,
The app loads 20 events at a time on the Events page. If you keep scrolling down before you delete all, you should be able to delete everything at once.
Thanks!. I should have clicked on that. I thought it would delete all events, not bring up the check boxes. This exactly what I asked for. Thanks! Love this cam
