I tap edit rules and it always takes me to create new rule. I need to edit the times and it won’t let me edit or delete it.
Welcome to the forums! After you press the edit rules button, are you clicking on the individual rules to edit them? If you click the edit rules button then the plus that would go into create a new rule. What app version are you using?
UPDATE: The only way that I found to fix the problem was to delete the plugs and reinstall them. At that point it gave me the ability to edit rules for each.
