This is my first day with the free trial plus I sighed up for the monthly service . New solar camera on Friday . This was working earlier in the day. Now it can’t access the cloud not impressed
Since it was working earlier in the day, the subscription itself is probably fine and it is more likely the camera connection or the app session. First check whether live view still opens. If live view fails too, it is a Wi-Fi problem, which is common with solar cams mounted far from the router, and you can see the signal strength under Device Info in the camera settings. If live view works and only Events or cloud playback fail, go to Account, then Services, and confirm the solar cam is actually assigned to your plan, since a new subscription does not always attach to the camera on its own. After that, force close the app and log out and back in. If it started for no reason and none of that helps, it is worth checking the Wyze service status page, since they do have occasional cloud outages.
