We had a 2-hour power cut over lapping when my rule for starting motion detection was supposed to kick in. It didn’t.
Anyone else has similar experience or you all have a reliable power supply?
Unfortunately, most rule changes are sent by Wyze servers, so if the device isn’t online then it must wait until the next rule change. There is no handshaking/retry.
They have started moving some simple scheduling to the device, tho. Not on the cameras yet.
Thanks for your response - much appreciated. I looked in vain for where to make suggestions and/or vote on such, but didn’t find it.
Such simple rules (switching on /off monitoring) ought to be designed to work whenever there is a powercut (we have a fair amount of those here in Costa Rica).
So if a camera (v3) is monitoring and there is a powercut I guess it will not resume either… Any idea? If so that would seem to be a very high priority feature to ensure.
Cheers!
All suggestions for further enhancements start out in the Wishlist and later show up in the Roadmap, but I never personally have an issue with any Wyze device and my old Netgear R6400v2 router.
Right - so you probably have a reliable mains power supply to your house, which is a different situation from mine.
I would love to have “retry on fail every hour” sort of feature. It would be awesome!
Realistically, the only workaround I can imagine is to set backup rules for anything important. We had to do this for our cameras that sometimes lost wifi connection and so wouldn’t execute on a rule. So that’s my suggestion for an immediate fix, set duplicate rules to execute every 2 hrs so even if a rule is missed it eventually gets fixed.
Hope that helps.
