After the last firmware upgrade to my two Wyze Cam2’s, I noticed that the camera could not be powered off of the small iPhone USB power blocks (the light cubes rated for 5V 1A). When connecting them to small battery packs that I have (also in a similar power range) I noted the same issue.
My V2 has 4.9.4.108. I’ve just measured current consumption at 330 mA in Day mode (with the IR LEDs inactive). That’s up a bit from what I measured last year when it was new (310 mA).
I don’t see any sign of a startup spike with mine.
What’s the symptom? No click-click at boot (as the IR filter flips back and forth? No blue LED lit on back?
Have not, but I am also prone to try and figure out these things as best as I can. I will try and debug now that I know I am a unique case and see if anything pops up. Probably a self masochistic side of me coming out.
It’s a really odd situation. You might try reverting back to the previous version of firmware (on one of your cams) and see if normal operation returns.
