Possible bug with Cam groups on iOS and Outdoor Cams
So I have 2 Outdoor Cams and 3 indoor cams in my Camera group on my iPhone 13. I noticed that I could not connect to either of the outdoor cams but the others were fine. I tried the basic troubleshooting steps but no joy.
A redditor mentioned that he had luck by removing the camera group all together. I removed just my outdoor cams and was successfully able to connect to them both each individually.
iOS, Basestation and cams all had the latest firmware. FWIW.
Hope this helps!
This is a known issue and is currently in development. The solution for now is to remove the outdoor cams from a group. Sorry for the issues, just keep your cams and app updated!
You also may wanna clear you app cache after removing them from the group with Account > App Settings > Clear
