I would like to see a decorative style porch light. The floodlight is good for the back, side of house, back of garage. But for your front door or lighting for garage where door is located at the front you want something a little more decorative looking.
Features could be:
- Integrated LED lighting, similar to floodlight so it is adjustable. Or, standard A19 bulb fitting for use with replaceable LED/Incandescent light bulbs or Wyze Bulbs.
- Dusk to dawn where light sits at 5-15% light (user selectable possibly) until motion detected then goes brighter (100% or user selectable).
- Integrated mounting plate for Cam v3.
- Added USB port (or 2) for additional Cam v3 or Pan v3. If single USB port, maybe a USB Y-Split Cable so that two additional cameras could be attached.
