The audio is garbled, and video is out of focus due to a few objects taking up a small percent of the view, I need focus set to 15’-40’
I need manual focus like my $5 webcam has… The audio is pretty much a joke you can make out about 1 word out of a sentence from a distance of 12ft.
The camera is setup with RTSP v4.28.4.40 and has a line of site to a router about 30ft away wifi signal is 77%
How can I manually adjust the focus? And fix that audio so the Wyze cam works as good as my used MS 1080p $5 webcam?
Running Blue-stacks for setup then RTSP to BlueIris both work great, the limitation is as mentioned above the Wyze cam.
