Plug google voice
Google voice not working with plug.
Welcome Back to the Wyze User Community Forum @redpoco! :raising_hand_man:
Can you provide some more details?
  • Is the plug the only device that will not respond to Google Assistant Voice Commands?
  • Which version of the plug do you have?
  • What Google Voice device are you using?
  • Have you recently enabled 2FA in the Wyze app?
  • Is the plug showing online in both the Wyze app and your Google device list?
  • Is the plug reacting normally within the Wyze App?
Yes
What is 2fa
You answered yes…
I have no idea which of those questions you answered. No way to help if I can’t narrow it down to troubleshoot the problem.
2FA is Two Factor Authentication that uses SMS or uses an authenticator app to give you a one time code to allow login.
