Plug for washer: notifying when done
Is there a Wyze product (plug: outdoor or indoor) that I could use with my washer so that it notifies me when wattage use drops below a certain level, effectively when the washer is done?
Not with Wyze on its own, unfortunately. The only Wyze plug with energy monitoring is the Plug Outdoor, and it tracks usage over time with an alert when monthly consumption goes over a level you set. There is no rule trigger for wattage dropping below a threshold, and the usage numbers update too slowly to catch the end of a cycle anyway. There is a long running wishlist thread asking for exactly this trigger if you want to add a vote.
If you’re open to other gear, a plug that reports live watts paired with Home Assistant or Hubitat can do it with a rule like “below 5 W for 5 minutes”, which also covers the soak pauses mid cycle. Also check the washer’s rating first, since the Wyze plugs are rated 15 A and some washers sit on a 20 A circuit.
You could use a vibration sensor (from some other manufacturer) to alert when there is no vibration detected for some period of time.
You might be interested in these Wishlist topics:
As with any Wishlist topic, you can visit those to click or tap the Vote button above the initial post and share your ideas and use cases in the comments to show your support for the product and feature request/suggestions that are important to you.
The vibration sensor route is the simplest place to start — stick it on the side of the machine where it shakes most, and set it to alert after a few minutes of no vibration so the soak pauses don’t trigger it early. Just check the washer’s amp rating first before putting any plug in line, as the plugs are only rated to 15 A.
