Playback not option since update
Procam3 all cameras do not have option for playback from sim on app. since update. unplugged, removed card and option came back but says it doesnt recognized card and wants me to buy service. Removed app and uploaded still nothing. Read about reformatting will try but seems to be the update cause issue.
This seems to be a common problem. Not sure why some have problems and some don’t while on the same firmware.
The odd part is that most people are not having a problem, but a percentage are. Unknown what is different.
BTW, it’s a uSD card - not a SIM card. It’s an abbreviation for Micro Secure Digital card. The Micro part referring to the size. There are also full size (referred to as Standard size) SD cards and mini SD cards.
Actually it is a µ (micro) SD card. I always wonderd what a ‘u’ SD card was.
Just need a better keyboard. :laughing:
Something changed on the back end after that big February outage, that made connecting more difficult for some communication hardware?
Either that or someone is slips-trimming fixes making firmware different even if on the same version; that’s a worse possibility.
That is correct, but frequently referred to as uSD because most people have no clue how to get the computer to type a µ . Not one I type often enough to remember the ALT number for, so have to look it up.
I have same issue. V3 Pro. Says SD card missing when hitting playback from an event. However, if I go to camera directly and hit SD Card, it plays back fine.
I noticed this on the Wyze release note.
" 2.49.3.399 (February 13, 2024)
  • Optimized the in-app purchase flow"
I wonder if starting this App version introduced a bug that instructs us to buy an SD card?
