Until recently, I can move my pip around my cell phone when in landscape mode. Now I can only move the pip portrait mode. . I then when I rotate to landscape mode the pip is in the middle of the screen and I cannot move it. Why is this ?? I am using a pixel 9.
I think I have resolved my issue with picture and picture movement. I have always been able to move the picture and picture in portrait or landscape mode on my pixel 9.. but it started to where I could not move the picture and picture in landscape but I could in portrait. I think I have found that if I open picture and picture in portrait it opens on the left. I can pull it down to the center below the portrait picture and then change the orientation of my cell phone to landscape and I can move the picture and picture. Imagine that
It was never like this before but at least this is a cure for me . Hopefully for you also if you have this issue. I have cam OG pixel 9 My app version is 1.0.98
I appreciate your taking the time to update your topic with information about what has worked for you. Since it’s unclear to me what Cam(s), app, and OS versions you’re using, I wonder if adding that detail might be more helpful in explaining your original problem and providing guidance to others in the future. As Cam OG and Cam OG Telephoto have a completely different (in-app only) PiP experience from other Wyze Cams, additional information about the situation could shed significant light on the issue.
