PanCam Problems
I have previously used my Wyze Cam Pan a few months back, and stopped using it. I and now using it again and I have two problems.
  1. The Pan Cam will disconnect after roughly 1 minute.
  2. It will occasionally make a quiet sound, sort of like a radio malfunctioning.
Please reply, I need to have this camera set up by 3 days
Try doing a reflash with an SD card.
https://support.wyzecam.com/hc/en-us/articles/360022732931-Wyze-Cam-Firmware
You can essentially reset the camera with this. Might take about 10 mins of your time. But should fix the issue.
And you can Check here later for all your troubleshooting needs.
Troubleshooting Wyzecam
I restarted my camera but the same issue persists. Must be the camera itself.
