Pan V3 seems to not even acknowledge SD card
I’m assuming you’re referring to the SD card?
If yours is the first issue, then it is firmware/app related and is the thing they’re working on in the thread @crease mentioned.
If it is the second, then the card has either reached the end of its rated life for writes, or something (faulty camera, power surge, card defect, etc) has damaged the card. So removing it and formatting it in a computer is worth the time, since SD cards have skyrocketed in price you don’t want to just toss it without testing it.
I’ve had SD cards go bad in all kinds of devices. Some from hitting the end of their life, others from apparent defects as a new card worked fine. There are a lot of reasons. Maybe yours is due to Wyze, maybe not. But if it happened after updating firmware, at least you have the option of downgrading the firmware and formatting the card (and hopefully the next firmware will resolve the issue completely).
The latest update for the cam pan v3 reportedly fixed the microSD card recognition issue. That may be true but not 100%. I have cards recognized in 1 cam pan v3 and not another. I get the ding ding for 1 and not the other. App and cams updated and yes the app update to 3.11 was performed before the cam update. These are Sandisk High Endurance 256gb cards.
The bigger issue is the update did not fix the not recording to the sdcard issue. I get icons and numbers for the number of events but no video. Just a message that no video is available.
Had high and perhaps false hope Wyze had fixed this issue. Wyze should consider offering free replacements for these cams but for cams that are returned to them or they disable via the MAC address of the cam.
100% agree. There seems to be a batch, or perhaps a few batches, of Pan V3 cameras which begin gradually developing worse and worse SD card detection/handling until eventually they just say the SD card needs to be formatted but can’t actually format it or do anything at all with it. I bought a pack of 2 cameras and they both eventually developed this, though it was at a different pace.
I thought I only had one bad batch V3-pan so I gave that one away.
Now the second one that was fine for years has decided to randomly quit recording to SD, and a power cycle fixes it when it happens :face_with_diagonal_mouth:
Wyze cams are just Crap :poop:
Setup up a rule in my hubitat to cycle power once a day.
I’m new to this group as I have recently discovered that my SD card is not working in my Pan v3. It sounds like I’m not the only one who is having difficulty where my SD card isn’t recognized, that the Wyze App fails to reformat it, and that it still failed, even after using my Mac’s Disk Utility to erase and format it as FAT32 (32 GB). My firmware is up to date on all my cameras. I even factory reset my Pan v3 and that ended up causing the camera to no longer connect for live video. After unplugging it for several minutes, it is now able to live stream.
Is there an app for the Mac that is a better SD formatter that I should use? I saw one mentioned for Windows and Linux.
Any other suggestions for Mac? Thanks.
The sdcard.org formatter has a mac version.
Keep in mind SD cards will just die. Especially the smaller ones, and especially if on continuous recording if they aren’t rated for that.
Have you tested a different card in it?
Hmmm, I didn’t realize that SD cards die, especially the smaller ones. What capacity should I get?
I don’t have mine set for continuous record. It’s on event record but I understand what you’re saying that my 2 to 3 year old cards could just be hitting their end of life.
I discovered that 3 out of 5 SD cards aren’t recording in my cameras. I’m a little scared to put a working card into another camera because I don’t want it to stop working. Will look for an unused one, or buy a new one to test it out as you suggested.
And I will look at the at the formatter again, but I don’t think it supports my MacOS version.
Thanks for your suggestions.
Each card has a different endurance rating. For example my Samsung Pro Endurance 128GB cards I calculated should last 14 years of continuous recording at the rates that Wyze writes at. a 256GB card will last twice as long (each cell writes half as many times when you double the capacity). And a 32GB would be like 3.5 years (again these are all 24x7 continuous recording numbers, motion-only recording increases that exponentially).
What capacity you should get depends on your needs. If you are not writing continuously, 32GB (or even less) is probably plenty, just get whatever capacity keeps the amount of history you want. But you should still get at least a middle of the road brand like Lexar or possibly PNY (though PNY has gone downhill somewhat). People actually seem to have good luck with the Wyze cards and I suspect they are either Lexar or possibly Kioxia as both of them do a lot of “white label” cards for other companies. Both are pretty decent for non-harsh non-continuous writing. I actually have a couple 8GB cards that came with my very old dash cams (generic cards with the korean cam’s name on them) that I use motion only on a couple cams that rarely see motion, they’ve been going 2 years without problems.
Unfortunately SD cards are at the most expensive they’ve ever been so finding a budget friendly option can be tough. Resist the urge to use Adata, Team Group, etc, unless they’re a really good deal and you don’t mind the fact that they’ll probably die on you at some point and it may not be very long. Even PNY is a crap shoot.
Non-endurance rated cards in “motion only” mode can last quite a while, but not all cards are created equal. Environmental factors, power outages, etc can impact their lifespan as well. I’ve seen a power outage take out a dozen SD cards at once (or more like the surge when it came back on).
I prefer the sdcard.org formatter as it basically resets the card back to factory default with all the proper offsets etc. But if you can’t run that, using the Mac’s built in formatter and doing a “full overwrite” or “non quick” format is probably second best. I’m not sure why it wouldn’t work on your Mac though, it should have pretty broad support.
Then put it in the cam and if it is at least recognized, try the internal cam format (just to wipe off anything the mac may have put on it, sometimes it likes to toss a couple mac related files or directories on there).
Which cards are you using?
While it is unlikely putting a working card into a non working cam will harm the card, it is not impossible. Of course the same could happen with a new or spare card so not sure there is really more or less risk either way.
Depending how advanced you want to get, the v3 now supports RTSP streaming where you can send the video feed to a NAS or PC and record the footage to a hard drive - far more reliable and you can get lots of capacity. Reviewing the files can be much easier that way too. But that’s obviously a bit of an undertaking and requires some tech knowledge.
Don’t use a Mac to format. Windows only. I have both and Windows worked for me.
Welcome to the Forum, @LisaP! :wave:
Not by a long shot. In case you didn’t see it earlier in this topic, Wyze has said that they’re actively investigating these issues:
Well they certainly screwed that up, a previously working V3-pan which didn’t have the SD card issue up until this month. So something changed and Not for the better.
Just another reason why Wyze cams are unreliable :roll_eyes:
I noticed yesterday that all of pan 3 cameras are having issues with the SD cards. I have eight or more of these cameras and none of them will connect to the SD cards now. Today I updated one of them to the latest firmware, and now the camera live stream won’t even load. Ironic as the iCloud motion detection sees there was motion on the camera.
I have a pan 3 camera that has been sitting in a box for a while, and I connected it up. It has an older firmware version, and it’s working just fine. I have not updated it the firmware on any of the cameras except the one today. I’ve not made any changes at all. The cards were working just fine. Wyze did something, again!
I spent money on Wyze-branded SD cards so I can have records of events around my house. Why they are not working? Are they trying to force me purchase their cloud recording option? I chose Wyze specifically because I don’t want to use cloud recording…
The SD card issues have been affecting V3 pans well over a year, I gave mine away and got other brands of cams. No more issues
Wyze branded SD cards are just mid range SD cards that they had their name put on, nothing special about them. Probably Lexar or Kioxia cards.
Nobody is trying to force you to get a subscription, and subscription does not change SD card recording. What symptoms are you having exactly - has it ever worked? Where are you trying to play the SD card video from in the app?
I’ve been using the same brand of SD card since I’ve been using Wyze cameras, which has been about 10 yrs. Shr I’ve had to replace 1 here or there, but to have ALL of your Pan 3 camera’s cards stop working at the same time, that’s something that points to Wyze as doing something w the Pan 3’s on their end. As I stated above your post back in May, I hadn’t made any changes, didn’t do any updates to my firmware nor the app. The 1 cam that had been sitting in a box, which I didn’t dare change fearing the same issue, now have the same problem. I’ve written to Wyze support several times about this, & to no avail. And seeing that I’m not the only 1 w this same problem, only w the pan 3 cams, shows definite pointing to Wyze. They refuse to acknowledge they’ve broke the recording to the SD cards, & they refuse to fix what they’ve broke.
All of my other cameras, using the same card, are working\recording just fine. I’ve even taken a card out of 1 of them, put in the pan 3, & same error. Put it back in the pan 3, & not recording error. I do have recording to cloud, so at least I can see SOMETHING since that recording to SD card is non functional.
GREAT support Wyze! NOT! Frustrating when I need to see more than is recorded to cloud. They are great cameras…. When they function correctly, as we paid for!
There were some issues with some Panv3s (not sure anyone ever figured out the pattern, neither of mine had it, some people had one, some had multiple) where they stopped recognizing SD cards. I believe that has been partially resolved with a firmware update earlier this year.
But @royalblood235 hasn’t mentioned if this is affecting multiple cams, or if theirs is even a Panv3, hard to say without further info if it may just be the cards, the way they’re trying to access the SD card recordings (which can be confusing), or something else.
I did do an update of the firmware on one of them in May. After I did, the cameras live stream wouldn’t load. So I ended up going back to the previous firmware I was using. The update did not fix the recording to SD card issue, just gave me a new problem.
You’re correct that he didn’t state if this was affecting his Pan 3, but since he was posting to the “pan V3 seems not acknowledge SD card” forum, it’s assumed he was talking about the pan 3.
Did you also update the app to the latest? Newest firmware has a minimum app version as it uses new security protocols. If not, then live stream and other parts won’t work.
Not sure you can say that for sure, if your app wasn’t able to authenticate with the cam and then sync settings between app, cam, and servers, the “fix” may not have actually happened. The firmware update does state something along the lines of needing both to fix the problems completely.
Yeah often people just jump on a thread that seems close but in reality isn’t related.
Yes, I did up the app as well. I have an iPad that I only update the app on to the latest version.
I’ve never had any issues with updating the firmware on any of my cameras. So after I updated the app, I updated the firmware on that one camera, then I had the new issue.
