Pan v3 rules question
I’m using the pan and scan v3 cam to keep an eye on my reptiles which happens to be in a bedroom (don’t ask)…. I set a rule to turn OFF the camera if it detects a person which is idea since it is a bedroom BUT I don’t see an easy way to turn the camera back on which would allow it to check for a person and once again turn off or more than likely it would just stay on as long as no on is detected….
Help?
Once the camera is turned off there is no way for it to turn itself back on when it doesn’t detect people because it has to be on to record events and use the AI.
Have you considered using a location trigger for this? This will not work with more than one person, but if there is only one person who uses that room it may work.
