I recently purchased the Pan v3 and I already subscribe to Cam PLUS. I have event recording turned on, device notifications turned on, and push notifications turned on in my iPhone settings. I still don’t receive notifications on my phone. I can see event recordings in the event log for the Pan v3.
I did notice what could be a glitch? (Unless it says this for everyone.) Even though Notifications and Sound Events are turned on under Device Notifications, there is a blurb at the bottom of that screen: “ You can’t turn on notifications until you enable Event Recording” with a clickable link to the Event Recording section. Lo and behold, they’re already all turned on.
Also, the newest app update has changed some of the notification channel options for the Wyze Global Notification Sound. This can be toggled in the Account → Notifications → Push Notifications → Sounds settings from the Wyze Sound to the System Default . Not sure if it may be related to that recent change. I don’t use iOS so I can’t test it.
