Recently installed firmware 4.10.5.111. I can no longer record motion while in pan scan mode. If i enable pan scan it disables the motion box. If i enable the motion box it disables pan scan. What do I do?
I think I figured it out. My motion detection was set very low. It will still detect and record motion on pan scan. Did the sensitivity get changed in this latest update? I feel like it was always detecting at least some movement even at very low levels.
I had a similar issue after the firmware update. No motion was being recorded on the pan cam at all. The motion sensitivity was at about 33%, and even shining a bright light into the lens did not create a motion recording. I raised the sensitivity up to about 2/3 and motion sensing works again.
