Just installed the pan Cam v3 but the ‘home’ position is pointing down the street not even showing my property. How do I change it so the Home position is where I want it ?
If you have the Pan Scan and the Detection Zone features off, the Home position will be the last position you manually placed it in.
If you have the Pan Scan feature enabled, the home position will be the position of your waypoints (up to 4).
If you have the Detection Zone enabled, the home position will be where the cam is when you save the Detection Zone.
