I don’t know if anyone else has this problem, but my pan cam is about garbage. Or it’s working for the fox or whatever other critter that is eating my chickens. I can use this camera for months without issue. And then when something comes into the yard and shreds a bird… I get NOTHING!!!
There’s no play back, now I have to go get a ladder and pull the dam memory card and see if there’s anything on it. I cannot tell you how many times this has happened. This pan cam is the most unreliable camera I own. I’m only using it because of the amount of space I have to cover without having to install 3 static cameras.
I hope it was recording, the last time I had a bird snatched it had stopped the day before and was just going through it’s programmed motions. You could view the camera live, but it wasn’t recording anything.
