Pan Cam double reports motion detection
Why does my pan cams double report motion? This is very annoying and interrupts and covers up important key functions on my iPhone 16 pro max during the long notification. Is there anyway to fix this?
Kevin
If it is just the sound, that bug has been around for quite a while. Sometimes it is one, sometimes 1.5, sometimes 2. If you’re getting two notifications (not just the sound but actual duplicate notifications) then you have two categories that are getting triggered like motion and sound, or if you have cam plus and are using AI detections you may have “other motion” selected which will often cause a second notification along with the AI one.
