The package detection for the video doorbell is great. But, it’s not an event with a short term end date. If someone isn’t home then that package sits there. We get spammed with notifications every 5-10 minutes that a package is detected. I see no options to limit this specific notification to every 30 minutes or any custom timeframe. So, create one. Wyze makes great products and the answer to this shouldn’t be “turn off notifications” for packages or “change detection zone” settings to avoid the notifications. I see that this has been a topic in this form since 2021. It’s a simple, deterministic code change. You don’t need to change anything with the AI settings, this is a time constrained notification limitation. Thank you for your consideration.
Any time there is motion, it analyzes the frame and if any of the objects you’ve selected are there, it will notify you. So if you can reduce your detection zone and/or sensitivity so that it isn’t catching motion that you don’t care about, it also won’t notify you about the package as much.
