Outward Door Mount For Wyze Duo Camera
Looking for a door mount for an outward-opening door. I have looked at almost every online store for them. Has anyone found one?
Welcome @nmadanier
Can you send a pic of where you are mounting the Camera? Are you looking at mounting the camera on a door? or around the door somewhere?
On the door. Right now, I’m using adhesive, and it’s about 6 to 8 inches above the door lock.
So you looking for something like this?
I saw that one already, and it only works on a door that opens inward.
Since it simply crimps to the door, I would expect it to work regardless of the direction, unless the tightening knob hits the door jam.
So are you looking for something that wraps like that? Want to make sure I can search for what you are looking for. Worse case, I can search for a 3D-Print option. :slight_smile:
