I have a V1 office base for the outdoor cam will it work with the V2 camera? Does the office base come with the outdoor camera V2?
Mike
Hi Mike, they both use the exact same base, so if you already have one, you don’t need another. You can buy a V2 cam with or without a base, but if you already have a base positioned near where you will be mounting this one, then you should be fine without getting another.
Thanks, now to find just the camera.
Wyze calls an individual camera an “accessory camera”. You may need to hit add to cart on the app before it will prompt you if you want the individual or the base also.
