Have noticed a significant delay between motion and the start of recording. I can walk from my car to the garage and the recording shows an empty driveway. Is there a way to reduce the delay
Yes, go to the settings for the outdoor camera, select advanced, then select sync time at the bottom. When you press sync, it will show a loading symbol, then nothing else. It may seem at this point it is not working, but it has (hopefully) synced the time.
Don’t know for certain if it’s on the OC but for a while there was a setting in the App for Hardware Decoder that affected the lag on Android.
