What is the expected life of lithium ion battery in Outdoor Cam in below 0degrees Celsius conditions(winter)before recharging.
Hello @Ctonkin and welcome to the community.
That is a hard question to answer as it also depends on the number of events it is recording a day. I have been able to get 2 months out of mine in cold weather but I do not know if that was a constant below 0, it may have gone above zero some also.
Thank you for the reply. The weather is very inconsistent in Alberta. For the most part it remains below freezing during winter so would anticipate a similar result. I will install where access for recharging can be done easily.
