OG camera recorded livestream/playback files way too large!
I have a new OG camera and I noticed recorded livestream/playback files are about 8x larger than they should be. Here are a few example recordings:
12 sec livestream file is 16.02MB
1 min livestream file is 80.92MB
10 min playback file is 837MB
42.1 min playback file is 3.6GB
In comparison, I recorded a 44.5 min playback on a V3 Pan and it was good at 439MB.
The OG 12 sec event clips are the correct size ~2.1MB.
The OG is continuously recording and I checked file sizes on the microSD. The 1 min files ranged in size from 4MB (night) to 10MB (day). The camera is looking at my unlit backyard, so this is what I expected.
Looks like an encoder problem. Can anyone else duplicate this issue?
Thanks!
My configuration:
OG camera firmware 1.0.71, Plugin version 2.47.0.1
Wyze Android app version 2.47.0.373
Moto E phone, Android V10
Here is the codec info from a OG cam playback recording file. I’m suspicious the Color Primaries BT.601 spec isn’t valid and not sure if this is the reason the recorded files are ~8X larger than they should be.
Wyze OG Codec Info
For comparison, here is the codec info from a V3 Pan playback recording file. The BT-709 settings are correct for HD video.
Wyze V3 Pan Codec Info
