Offline floodlight
Installed: Wyze Cam Floodlight v2, no SD card. 4 cams in total installed. I had a T-Mobile outage. After signal restored only the newest Wyze Cam Floodlight v2 showed as off line. Camera is 500 miles away. Do I have any options other than driving up there to get it back online. SD card will be added on next trip. Thanks.
Do you have any way of remotely cutting the power on and off?
I may be able to contact a neighbor. It’s worth a try.
All my cameras at the remote location as well as at home are plugged in on smart plugs for situations like this. If needed I can remotely reboot them. I’d suggest you install a smart switch for your floodlight and smart plugs for any other models.
I’ll look into the smart switch. Trying to remember if a 2 gang box or 2 singles that were installed.
Thanks for the suggestion.
Floodlamp V2 intermittingly going offline
Floodlamp has gone offline on 2 occasions, and requires a power disconnect / reconnect to restore function. The other cameras (V3) have no issues). I have verified firmware level, deleted and readded the floodlamp after the first failure. My other floodlamp (V3) is a bit further from the router and has been error free. The inside cams (V3) are in the basement and have had no issues. These cams are remote and cannot easily be reset.
I merged your topics for continuity and to abide by the Wyze Community Guidelines with respect to crossposting.
