I have V4 Cam. There are times a movement is not showing up on notifications. I have the settings set night. There’s no rhyme or reason why it does this.
Are they showing in the app but not notifying you on your phone? I don’t have experience with Apple but on Android if I don’t do the below, I won’t get all the notifications (just sporadic ones).
In the wyze app, go into the app settings and enable “running in background”
In your OS settings for the Wyze app, set it to unrestricted battery or not allow the OS to put it to sleep (whatever Apple calls it).
When I do those things, I get all notifications reliably.
One thing I have noticed, if the wyze app updates or I reboot my phone, I have to launch the app and either view a couple cameras, or go toggle that “running in background” off then back on to get it to run in the background again.
At least with android, it gets very aggressive about saving battery and RAM and puts apps to sleep. I haven not noticed any impact on my battery life by doing the things above.
On top of the background setting above, it is worth checking the notification schedule in that camera’s settings, since a night-only schedule can make it look like events are being missed during the day. Also on iPhone, a Focus mode or the Scheduled Summary option for the Wyze app can hold or hide alerts, so check both in the iOS notification settings. It also helps to compare the Events tab against what you got alerted for, to see if the camera recorded it at all.
