Notifications do not identify which camera
I’m not sure when this changed or why, but it seems like the new notifications just do not properly identify the camera they are coming from. It seems like sometimes I guess it would say the camera very late in the body of texts, but that mostly gets cut off at least on iOS. Is there anyway to change how the notifications come in so I can see what camera is coming from? The camera that the notification is about should be the very first thing in the notification. Without it, I mostly have to open up every notification to see what it’s talking about, and that makes the AI summaries pretty useless. I have multiple cameras in multiple driveways so that bottom notification really tells me nothing now.
Are your cameras uniquely named? It looks like you have cam unlimited pro. My notifications with cam unlimited identifies the cams based on the unique names I have given them. Perhaps this is an issue to report for the descriptive phase of this service.
Yeah for sure they are all named. The first notification I shared actually does have the name at the very end of the description which honestly I didn’t even notice u til I posted here. The second shot I shared is from the same camera and you can’t even see the name. I’m almost better off going back to a normal subscription with it this way at least I would know which camera sees motion or get triggered.
Sorry, that’s a frustrating way to find out which driveway a motion alert came from, especially when the summary is the part you rely on. I don’t know of a setting that moves the camera name to the front of the notification, so your two screenshots might be worth sending to Wyze support as feedback. I believe the Events list in the app shows the camera name for each event, which could save you from opening every one.
It might help to post your feedback here
Wyze Stories - Released 9/1/2026 - Wyze News - Wyze Forum
Hi nlanzano, sorry for your experience. I will work with team to see how to improve it.
Since you are getting a Story, it is a summation of your camera activities. This seems pretty acceptable to me since the Story is comprised of multiple cameras. If this is 1 camera, I can understand what you are asking for but at the same time… I would guess you don’t need the app to tell you about your 1 camera that is alerting you.
I personally DO NOT want it to tell me about which camera is telling me that in the Story. If I need to know, I will click the story and get the Story Summary to see the cameras involved. Less is more in terms of notifications.
I guess the issue I have, and it’s an issue for my personal set up, is I have multiple homes with multiple cameras, all of my homes have driveways, two of them have pools, and previously I had them all labeled, so when there was an event at a specific home with a specific pool I know more or less what is or isn’t going on there which allows me to either react or ignore that notification with the AI description. Now all I get is that there’s an event going on at a pool or someone is in a driveway and it could be any pool or any driveway. The only way for me to find out is to open the app and start investigating. When really, before it would tell me that my home in Florida, there’s someone in the driveway and I could tell all that just from the pop-up notification.
First world problems, I know. But it worked much better before stories was a thing.
Fair enough, I can say I don’t use the cameras at the scale that some of the community does. Your use-case is a good argument for what you are asking. Probably a compromise in there somewhere in terms of not being too much but adding some flavor to the alert.
Good Suggestion
Yeah. It’s really a very simple fix. Currently the very end of the description they just throw a sentence in that is the name of the camera which normally gets cut off by the banner notifications or if you don’t expand the notification. Just move that line of the camera name to the beginning and replace the . with a : and problem solved basically. Looks like they are watching so hopefully listening and it’ll get better.
