I have the Wyze skill downloaded on my Alexa app but when it goes to discover all 3 of my cams it only shows and connects with 2. The 3rd cam shows as my Hp Officejet printer! And yes, all cams are up and running on the Wyze app. Does anyone know how to fix this? Thank you for any and all advice.
All are on the same network??
I’d try and log out and in on the Alexa app, then Discover devices again.
Restarting everything again worked. Thank you!!
Yes, they are all on the same network. Found the answer thanks!
You’re welcome… I’m glad that we could help.
