No recording issues (again) and SD card problems
Like so many, having going issue with events not being recorded despite obvious activity (car pulling up in drive, animal in yard). Despite having Cam Plus Unlimited, and all cameras have SD Cards, nothing is recorded, but it will also identify a waving tree branch or changing light …sometimes! I have now also discovered that a large percentage of my SD cards will not record and count be formatted, they either refuse to wipe the card or they return “format Failed” and then it say non-compatible SD card. Sometimes I can recover on computer, but often that card is now trashed. I have 20 cameras of all type V1 thru 4, Pans etc. Also notice it tells me that some cameras can join Cam Plus, when EVERY camera is supposed to be on Cam Plus UnLtd? Sadly I (and many other) think WYZE is technically tripping over itself…fix it or loose customers.
For the cam plus - smart detections require a stable upload bandwidth with decent wifi signal to work, I would start there (also disable “other motion” which does not use AI, but can still take away bandwidth from the AI detections).
For the SD cards, what kind are you using? If you are continuously recording or even if you have a lot of events recording, you should be using endurance rated cards or they can get worn out quickly.
