No Patience
Router rebooted. 4 bulbs were connected and I can’t get them reconnected. Over an hour just to try to get one working. No go. Into the garbage they go. Hope the cams and plugs aren’t this difficult or they will be joining the bulbs.
Can you be a little more specific? What errors did you get? What troubleshooting have you attempted? Which bulbs? What firmware? What App version/platform? Have you tried another phone? Have you logged out and back in on the app? Cleared the cache?
That seems a bit hasty. This is a user to user forum for help with troubleshooting and sharing information about the products. I can understand your frustration, but this isn’t the correct place to simply complain/vent.
That being said, many of us are helpful or have things that we’ve done to correct issues similar to yours. In order to do that, like @WildBill said, a bit more information would be helpful.
Are they still under warranty? Wyze has always been good about replacements if they’re defective.
For what it’s worth, I have 8 bulbs and haven’t had any issues recently.
