No option to set up wifi on camera base station, nor later
I’ve had to install the spare camera base due to an unfortunate destructive even with the first.
It sets up fine and sees the cameras, but I didn’t get an option to set up wifi, nor do I get the option later…
I didn’t have this problem the first time around, so I assume I’m missing something obvious.
If the base is setup over Ethernet, go into the base station in the app device list, then settings, then device info, then “wifi network”. From there you can setup the wifi information to be ready when and if you want to unplug it from the Ethernet cable.
Make sure your base firmware is up to date as well.
