We have trains that come by regularly. You can hear the engines in addition to the whistle. I have sound notification on of course but is there an option to not get train notifications? Can i create a rule for this?
You would need to turn off “other sounds”. This is assuming you have Cam Plus, if not your only choices are to try turning down the sensitivity or disabling sound events completely. Personally I disable them completely, too many false alerts.
on the bright side, you’re halfway to an epic country song!
