No events of UPS and others delivering packages
Looking at the Wyze app on my iphone, there were no events captured of the last 4 package deliveries to my house. Has anyone else noticed this on their phones? It captures everything else including me retrieving my packages.
Anyone have any ideas? Thanks!
Detection setting may be set to low. Not sure how much you know about settings. On my Android phone, on home screen go to devices, click on the camera you want, the settings wheel and then detection settings. Some quick small movers you may have to increase sensitivity. Some cameras I have at 40% some at 90%. (Also depends on how far camera is away from movement.)
Also in same area, under event recording is all motion events clicked?
From my iPhone yesterday with V4, V3 looking out a window and V3 PRO.
Delivery captured just fine. Pickles from New York :yum:
You don’t have pickles in California :rofl:
Are you using Cam Plus? If not keep in mind there is a 5 minute limit to how often events will log. They will record (if you have an SD card), but not show up as an event or send a notification. Maybe some motion before the UPS delivery caused the delivery to fall into that 5 minute “cool down” period?
Not real traditional brined ones, only the ones from the commercial producers.
357 Grand Street
Lower East Side of Manhattan, New York.
Next time I’m in New York, I’ll make sure to pay them a visit. Here, in the greater Toronto area there is a small Polish grocery chain Starsky. They have real brined pickles that you pick them from the bucket full of brine. :yum:
Thanks for all the replies. The sensitivity is good. It captures the mailman each day that the mail is delivered. Maybe it’s dumb luck that the last 4 deliveries were made during the “cool down” period? I’ll keep an eye on it.
Thank you all for your help!
