No detections and will not update firmware on v2
I’m having issues with one of my cams out of 5. Multiple resets have not helped. I Noticed I still had the 156 firmware and have attempted multiple times to upgrade to the October release. It will go through the download motions to 100% and then nothing. It remains at 156 firmware and still doesn’t record or detect anything…it is not even recording to the sd card. I have another cam with same firmware and card and zero issues…
Have your tried a manual firmware flash to the updated firmware?
That was gonna be the next step. It also finally just flat out refused to recognize the sd card even being present. All while the live stream was fine. Out of frustration I unplugged it again but this time left it for a couple hours…magically fixed everything…
I hope they turn things around…
Did you leave the card out of the camera when you restarted it? Glad it magicily is working now!
Nope, just aggravatingly pulled the block out of the wall and went to the grocery store…got back and just plugged it in…had thought about removing the card but was just sick of dealing with it after finally getting everything going smoothly a couple weeks ago after having to deal with some bricking from failed updates.
