I was able to unmute web views for audio. Now that is gone. Audio on web view has been an issue for 4 years. I could “fix” it by unmuting but not anymore. This is the last straw. I will not be renewing my subscription if this is not fixed and maybe others will do the same.
This has been a known issue for years. Audio works on the phone app but not the web portal.
Wyze support has continued to blame this on old camera firmware. Trying to convince me to buy newer cameras. This clearly is a backend issue. Otherwise the audio shouldn’t work on the phone app. You guys just continue to ignore this problem. Probably because the majority of users just use the phone app.
The event clips users watch all come from Wyze cloud servers. Doesn’t matter if you’re using a phone app or browser. If your clip has audio in the phone app, the browser clip should have audio too.
May want to change your reply subject to WyzeJasonJ
Don’t think he cares. He’ll just continue to gaslight people to buy newer cameras. I complained about this issue before on other cameras (V3 Pan, Battery pro). Now it’s spreading to the V4. cams.
Lets talk common sense then. Where do you think the event footage comes from when you’re watching on the phone app?
A: It’s coming from a Wyze cloud storage server.
B: It’s coming directly from the Wyze camera.
Similar question. Where do you think the event footage comes from when you’re watching on a web browser?
It should be from the exact same place. There shouldn’t be any discrepancy when reviewing the same events on a phone app versus on a browser.
Tried that before. Got the same response from you. The only new thing is the problem seems to be spreading to other cameras (wyze cam v4).
