I never hear any audio, even when the speaker icon is on.
Thanks
Thanks
Have you turned the “Record Sound” option on for that particular camera?
Hi,
Thanks for the response.
Yes. I checked advanced options and it was on.
Someone had posted to turn off night mode. I did, but still no luck.
Any further suggestions much appreciated!
Frank
Place a radio or Other device capable of playing music at a conversational level near the camera and see if you can hear that.
If still nothing you might consider contacting support.
