Night Vision Mode
Can I force Night Vision Mode ON when set to Auto and too much ambient light available to switch to Night Vision automatically at night ?
You can’t automate a setting change to IR NV ON. There are no Rules Actions for the Night Vision Mode in the Rules Engine.
To change it in a V3, it has to be done manually. The easiest way is to use the NV Mode toggle in the upper right of the Live Stream viewer.
You can change the settings for the Night Vision Conditions to Dusk to try and get it to flip to IR NV in low light rather than Dark\No Light, but if it still won’t auto switch, the manual toggle is the only way.
Thanks for the reminder. Knew this at one time but forgot until you just reminded me
Worked perfectly…Thanks
Awesome! Glad you found a solution!
