Night Vision Constantly Turns on and Off Wyze Cam V 4
Night Vision Constantly Turns on and Off in Auto mode and Night Vision IR lights enabled. Seems to be stable with the IR lights turned off. Wyze Cam V 4. Firmware version 4.52.8.0648
My guess, the IR lights are reflecting off something at just the right angle to make the cam think it is light out. Changing the angle of the cam a bit might help, or if the v4 has the “near” and “far” settings try changing it to near.
Can you post a video example of this occurring, so we can see exactly what you’re seeing? Thanks in advance!
There is a motion sensor for a floodlight nearby, I moved that away from the camera slightly and seems to be working OK. Also slightly rotated camera away also. Will monitor tonight . Thanks for the tip.
Neighbor had a similar situation. Most motion sensor lights up until a few years ago use infrared to detect motion and turn on. So when the camera turned on the iR lights, your motion sensor light turned on due to the IR, then the regular light from the motion sensor light turned your camera back to day mode. They’ll continue dueling like that indefinitely.
