Night Light Around Base of Outdoor Security Light
I’d love an outdoor camera security light which uses a base ring around the fixture as a night light. Dawn to Dusk, intensity, light color, or the ability to force it on or off would be great available settings. I realize some security lights dim the main lights when no motion is detected, but I prefer those be off unless they detect movement and more importantly, this night light sheds light in all directions right where the fixture is mounted instead of projecting forward or directly down like current options. This option seems well within your wheelhouse and would make the area around the fixture more visible. I have included a picture to help clarify my description. Thanks. Wishlist
@aced486 , welcome to the Forums. The idea of accent / Nightlight on the base is interesting. I moved this to a Wishlist topic so that individuals can Vote and Wyze can consider this for future updates.
However, you need to Vote on the Wish, by tapping on the Vote button at the top left. One is not added automatically
How do I add this text that I accidentally erased just before it was flagged? Sorry, first time poster.
Not a problem.
I just unlocked it as I removed the Code block so your initial text remains intact and makes it easier to read.
To edit the text click on the pencil below your post. You should be good now
Thank you for your help!!!
My Pleasure. Great suggestion
