I’m looking for an easy guide to help to find out what product do i need. I can’t really tell my requirements so far because of knowing nothing. If there are options, that will be great. I guess i can start with camera?
Are you going to use the camera (s) indoors, outdoors or both? Do you have power available to plug the cam in at the desired location? If you have power available the best all around use would be a V3 or V4 camera in my opinion. V4 is the better of the two.
You may want to read the posts in this forum before deciding on any Wyze cam, plenty of problems compared to most other camera systems…..
Ask me how I know?
My Cameras used for Security are NOT Wyze cams
Wyze cams are only useful in non-security settings in my opinion and many others. Wyze cams are just TOYS
Perhaps if you mention what you want to use the cameras for, it can help narrow down the choices.
