Hi, I got my camera all set up and inserted a 32GB micro SD card. It’s working fine but I’m wondering if I can disconnect the long cord from the camera and put it in another room? it is connected to my wifi. Thanks. LR
You certainly can move the camera to another room. As long as there is adequate wifi signal from the same wifi network in that room, it will reconnect automatically as soon as it is plugged back in.
The cameras do not have a battery and must be connect to power full time. The cord runs from the supplied power block plugged into the wall to the small microUSB port on the camera. The larger USB-A port on the camera is only there for powering another camera in sequence and normally will not be connected to anything.
