Needs an off switch in App!!!!
Please consider adding the ability to turn the camera off/on from the app. I have limited upstream bandwidth… if the camera had this ability I’d be able to install a few more around my property and turn on/off as needed.
Thanks, Rog
If you have notification alerts turned off and you are not viewing the live stream or playback, then the camera should be using very minimal bandwidth. Even with notification alerts enabled, it is only uploading 12 seconds at most every 5 minutes. Also, it will use less bandwidth if you switch from HD to SD mode.
